fitted new cowl to rad to try to stop over heating, same time put new ( put one in was not fitted) thermostat in,
replaced engine oil W30 fitted new oil sender, and bulb for oil light, started it up and great oil light came on then with slight revs goes out
but engine temp on tick over hit red, removed thermostat temp ran at low normal.
put topper on mowed some old thick grass for an hour then oil light started to flicker then 20 mins later it will only stay out at half revs, engine temp was running at 165% normal run temp.
so any ideas i am thinking the worst and a big bill ££££££££££££££££££ any suggestions will be great, please don't say scrap yard.
thanks
