Super dexta sleeves
Posted: Thu Apr 07, 2016 7:34 pm
by Bchaney
Hi, I'm going to have to put new sleeves in my super dexta. I got a rebuild kit from Agriline and the kit has semi finished sleeves with no flange. The sleeves in the motor look the same but the guy at the machine shop said on the phone that I got the wrong ones. He said if they didn't have a flange(lip) they would fall out. He said he has rebuild a many Perkins 152 and they all have flanges. I did see on YouTube where a man put some kind of lock tight on the sleeves of a different engine. Any thoughts? Thanks Brent
Re: Super dexta sleeves
Posted: Thu Apr 07, 2016 9:53 pm
by shawnee
Probably all the massey ferguson perkins p3 152 that he has seen does has lip on the liners, but super dextas are f3 152, ford cast block put together by perkins, with perkins parts to ford spec's unless, it has been machined.
Posted: Thu Apr 07, 2016 10:35 pm
The mistake your mechanic is making is there in your post. He is referring to a PERKINS 152 not a FORD 152 as fitted in the Super Dexta, they are two different engines.
Ford liners are pressed in with Loctite or similar locking compound. They are a tight fit and deform when fitted hence the reason they have to be bored to size after fitting. Tell your man that these engines have been running that way for 50 years and the liners have not dropped out.
Posted: Fri Apr 08, 2016 3:33 am
by Bchaney
Posted: Fri Apr 08, 2016 3:51 am
by Bchaney
I decided to try to rebuild the engine myself. I got my rebuild kit in and it has rope seals in it. Is there a certain way of installing them? I didn't see anything in the manual,in case I missed it. YouTube shows some people soaking them in oil before installing them. Thanks
Posted: Fri Apr 08, 2016 4:13 am
by shawnee
Posted: Fri Apr 08, 2016 1:20 pm
by Bchaney
How would you remove the sleeve? I've heard things like breaking them out,using a torch and screw driver and a press.
Posted: Fri Apr 08, 2016 6:58 pm
by shawnee
I
Posted: Fri Apr 08, 2016 9:44 pm
You are finding out the hard way that you need a machine shop. They can press or bore the sleeve out, install the new sleeve and get it bored to the correct size.
One of the first problems on this board over 15 years ago was people who attempted to re-sleeve Dexta engines without the aid of a machine shop, by fitting the sleeves and then honing them out. We had quite a few people who seized up reconditioned engines because the job was not done correctly.
You cannot draw the sleeves with a tool for pulling wet liners, it is a completely different tool. If you try to chisel them out and mark the parent bore you will then be in difficulties with fitting the new liner. Some people avocate welding a bead down the liner and shrinking it out but with my luck I would weld it to the parent bore. Even if you get the sleeves out you are still going to have to size them to the correct bore size.
Sorry, but with the limited experience you have, you need specialised help from a good machine shop.
Posted: Sat Apr 09, 2016 1:54 pm
by charlie63
Posted: Sun Apr 10, 2016 8:12 am
Charlie, Loctite or similar is recommended by Fords in the Service Data Sheets.
Posted: Sun Apr 10, 2016 10:52 am
by charlie63
Brian,
Just realised that I had put not to use loctite. Didnt check what I had written before posting as I used beads of loctite on my liners when they were pressed in. Sorry for the wrong information. As you say even though they are interference fit it is recommended to use loctite when fitting.
