1961 Fordson Dexta Dual Clutch Assembly Refit
Posted: Thu Jul 14, 2016 4:13 pm
Hi All!
New member from Tennessee here, so I just want to start off by saying hello. Also, I have lurked around the forum for quite sometime taking full advantage of this wealth of knowledge on these awesome tractors! Awesome site you guys and gals have here!
Ok so now down to business. My dexta has the dual clutch, and it starting giving me trouble about a month ago. It started intermittently by not wanting to go into 3rd gear (in hi or lo range). It would grind even when fully stopped, and revving at low rpm's. So at that point i knew something wasn't right. Then one day, the clutch simply would not disengage. The pedal felt very soft. You could start the tractor in neutral, throttle all the way down and then finesse it into gear, but you better not want to get it out of gear suddenly. To stop, you had to just kill the motor. If the tranny was under any kind of load at all, you couldn't pull it out of gear with team of mules lol.
At that point i knew i had major clutch issues. I split the tractor (with the help of the awesome manual that i downloaded for FREE) and pulled the clutch assembly. Disassembled the clutch assembly, and found the transmission clutch disc had all but exploded! I have attached pics of said disc.
I have 2 questions: Should I just go ahead and buy an entire clutch assembly, or try to find new disc(s)? Next, if I buy a new assembly do I need any special adjustment tools, or is it a simple bolt on type of deal?
Thanks,
TNengineer
well, i guess i should have read the "posting images" thread before adding them into my post. Gonna resize them then post in another comment.
Thanks,
TNengineer
