Extract from http://www.fordsontractorpages.nl/phpbb ... 47&p=16350
Just putting a new radiator on my Dexta and researching the best way to mount it with regards to the rubber mounts. There were rubber mounts on the old radiator I took off but they certainly were not original and looked like a piece of conveyor belt. One of the tractor parts suppliers sell a rubber pad that I presume is similar to the original supplied with the tractor. https://www.agrilineproducts.com/Catalo ... ford-dextaBensdexta wrote:The Parts List lists 6 support pads for the radiator, two between radiator and axle support bracket and one below, ie 3 on each bolt. The Parts List gives part#E43MB9, although interestingly the vugot on-line parts list gives a different part# for the lower pads 81717121.
This seems to be confirmed by the workshop manual for the cooling system, radiator replacement:
"Place the radiator in position on the front axle support bracket, with the two large rubber pads between the radiator and bracket. Replace the small rubber pads, flat washers and self-locking nuts in that order on the bolt, and tighten the nuts up until the rubber pads are just compressed."
Brian commented on the old website that for the Fordson Major the pads are about 1/4" thick and the same as the pads under the fuel tank, and made of 'hard plasticised rubber'.
I wonder if Stefan can give chapter & verse - he often can?
I had an old rubber car mat that I thought would suffice. I cut two strips that fit inside the bottom mount of the radiator and another piece underneath the bottom of the radiator and then a cut up strip underneath with the washer and nut to secure. I was just wondering what others have done. I have rubber running the complete length of the radiator whereas the rubber pads/ rectangular pieces supplied are two separate strips that look about 2-3 inches long.
More than likely both methods will suffice. Just wondering would I be better off keeping it the same as it was fitted originally and have a smaller piece of rubber rectangle at each bolt and have a void air space between the two or keep it running all the way through.
Any comments on the fitting method of the rubber mounts would be appreciated.
Thanks Pat
