Misfire
Misfire
What would cause a misfire upon startup some times, leaking atomizer valve, injector nozzle leaking fuel into cylinder, it runs for a few seconds burns fuel off, a lot of smoke then runs OK? Any ideas? Broken valve spring? Have not pulled valve cover yet? And that is just sometimes at random! Any
Re: Misfire
Injectors or any of the things you mentioned. Also cooler weather will cause it.
Check to see if you have a small tap on the primer line to the manifold heater. This should be turned off until you use the heater and primer.
Re: Misfire
No cut off tap on atomizer valve I think I an going to put one on.
Re: Misfire
It was gummy fuel they do not make it to last as long, high price but
cheap made.
