I just thought I would share this for anyone who might want to clean their cold start fuel jet in future, as although I found mention of disassembling one, it wasn't clear and I couldn't find any photos myself;
Here is the fuel jet when I first got it apart. As you can see, the collar has an internal screw thread so an appropriately sized screw can be used to pull the collar, the ball and spring then followed.
I was then puzzled because I still couldn't see through the jet and couldn't seem the clean/clear it. After a week of soaking the jet in various solvents a further piece fell out! There is a final copper bung with a helical groove around it's edge which must be intended to 'swirl' the fuel before it is forced through the eye of the jet. Everything was so gummed up with carbon that this was jammed solid on mine, no surprise that fuel couldn't pass. Now that it is all cleaned up and reassembled I can blow through the jet without any troubles.
L-R:- Jet Body, Helical Bung, Spring, Ball, Threaded Collar
I'll refit it at the weekend and finally be able to use the proper cold start procedure!
Hope this helps someone
