Replacing the ignition switch 1960
Posted: Tue May 09, 2017 5:31 am
I believe this is a 1960. It is NOT a Super Dexta.
Went to start the Dexta today and it didn't work out well. Turned on the key and everything was fine. As soon as I pushed the starter lever I lost all power. The battery is charged and the fuse is good and there is power there. I've noticed the last couple of times I used it that I had to wiggle the key to get the power to turn on so I'm thinking the switch is bad. There appears to be 6 screws holding the cover on that houses the switch. 2 on each side and 2 on the front down near the bottom. When I turn the ones on the front they will not come out. Feels like there are nuts on the back turning with the screws.
Can anyone tell me what I need to do to get this cover off.
Thanks for your help.
