,now when i run tractor pressure is at 50 but when i drop rev to idle the pressur dropes
down to around about10/15when i rev tractor rev will go up to 50again
, im thinking this is normal could someone confirm this or should it be higher than 15 at idle , there is no blow
on breather tube and nothing coming from dip stick hole hot or cold, im thinking i should have just left oil light on
instead of bloody guage,
