For those of you who don't know : The engine has been completely re-built (about two years ago) and whilst examining the original oil pump, I found some cracks around the top two fixing holes, so I ordered a new pump (from the land of nearly right
Two years later I have finally got round to replacing the pump, so I have taken it out, and before putting the other new one in I wanted to check that it would work. So I have taken all three relief valve assemblies apart and found that the plunger in the old original pump is 1.6mm shorter than the newer ones, plus the spring in the old original pump is a coil shorter than the newer ones and the old spring is not as tough to compress as the newer ones.
So obviously the reason my oil pressure is high is because the plunger is longer on the newer one and therefore it takes more pressure to let oil by, plus the spring is tougher to compress and takes even more pressure to let oil by.
Do I put the old relief valve assembly in a new pump?
Do I shorten a new plunger and try that?
Has anyone ever come accross this before?
And why don't things made these days work properly, it really annoys me! Surely they should be tested before being sent out and sold?!
