have a replacment pump i could do with any tips or advice on removal and replacment of pump
thanks
spike
replacing hydraulic pump dexta 1958
FarmallM51
Re: replacing hydraulic pump dexta 1958
I couldn't find a gasket so I made my own from material purchased at auto supply business then used oil-resistant silicone on both sides.
Agriline do the gasket @ £4.50 + vat https://www.agrilineproducts.com/parts/ ... son__Dexta
You may find it quite tight to get it pulled of the two dowels, I'd spray the dowels with penetrating oil a day or two before starting (especially if its not been removed in a while)
kiwiland dexta
