Dexta Casting Codes
bobfaecullen
Dexta Casting Codes
Post by bobfaecullen »
Hi All,
Does anyone know where I can find the list of casting code dates nowadays please
Bob
Mervyn Spencer
Re: Dexta Casting Codes
Post by Mervyn Spencer »
Hi Bob, just above you post about 2 lines you will see an unofficial casting code post. Open the post and read the contents.
Mervyn.
bobfaecullen
Hi Mervyn,
Thanks for info but that is engine casting codes, will probably still be useful, but there used to be a list of casting codes that could be found on gearbox, axle trumpets, back end castings which pointed to a date that the castings were produced. My original dexta has casting codes B10B - 10th Feb 1958 - info I found on the list. Maybe someone has a personal copy of this list which was at one time available on the website and could post it as a sticky, would be a shame if it has been lost.
Bob
Mervyn Spencer
Hi Bob,
I'm sorry I did not look properly. I have a copy here with me but am not sure how to copy onto the forum.
Maybe if you forward me the various codes I can look them up for you. Failing that I'm sure you will find them if you went onto the wiki, I am not sure of the password or user name :(
bobfaecullen
Hi Mervyn,
I had a look on the wiki but they are not available there, they used to be on the website before it was cut down to what it is now. I will send you a pm with my e mail address and perhaps you could e mail the list to me if possible please, I'd like to have a copy of the complete list.
Bob
Mervyn Spencer
Always a pleasure.
Regards Mervyn
bobfaecullen
Thanks to Mervyn I now have a copy of the document I was searching for.
Now can anyone post a copy as a sticky on the forum so that everybody can see it again.
Bob
blackbob
Post by blackbob »
1440276 - 1957 - working
1335674 - err - one day..
Ford 7710 2wd, 1983 - working
