Underslung or Vertical Exhaust?
Wee59dexta
Post by Wee59dexta »
Hi all. I've been on a few road runs this year. The longest being a 40 mile all round journey to a show. Now, I got thinking after experiencing the familiar taste of diesel fumes on my teeth for about an hour wether or not a downswept exhaust would result in a nicer drive? I have to admit, as a matter of personal taste I do prefer the underslung look. Having driven a few grey machines I know the underslung exhaust is quieter, and I've always preferred the look. Unfortunately I don't do any field work therefore being choked whilst hitching and low clearance etc isn't an issue for me.
Also, was there an underslung system on a standard Dexta? Interested to hear your thoughts.
Re: Underslung or Vertical Exhaust?
Ask a few Fergy owners about downswept systems. As I understand it, a following wind will keep you immersed in fumes.
Is your silencer tip high enough?
Wee59dexta
My silencer tip is the standard height I'm sure. Thats a very good point. I think maybe it's more that I prefer the look and it would make mine that little bit different at shows etc.
Thanks for your reply!
Mervyn Spencer
Post by Mervyn Spencer »
I have been pondering whether a slightly longer top section with a bend outward of the vertical exhaust. :scratchhead:
bobfaecullen
Post by bobfaecullen »
I will give you a few comparisons as I have a dexta with the standard type vertical exhaust and my recently acquired vineyard dexta with an underslung exhaust.
The vertical exhaust is definitely noisier while driving, it is surprising how much quieter the underslung is.
I can get the underslung into a much lower shed.
The underslung almost chokes you to death while hooking on an implement and as previously said you are in a permanent cloud of fumes if in a following wind......although my vineyard dexta could do with the pump being overhauled I think.
The underslung exhaust gives you one very hot foot, if you rest it on the footplate, maybe that might be a good thing on a cold road run :D
Having now driven both I definitely prefer the vertical exhaust - but that is just my opinion. Hope it helps with your choice.
Bob
