Stop Cable Clamp
Posted: Mon Jul 06, 2020 1:02 am
Folks,
Just wondering if any of you could provide photos or advise on the clamp the holds the stop cable in place at the fuel pump. Correct me if I'm wrong, but I believe it screws on between the pipes leading up to the injectors and prevents the stop cable from moving about and prevent stopping the engine efficiently when pulling the stop switch. Also, was a spring at the far end of the stop cable, also attached to the fuel pump in order to reset the pull to stop to engine running mode, standard issue or a later adaption?
Do you know where I would get the stop cable clamp for a 1964 Super, if that's the proper name for it?
