Throttle shaft
Posted: Sun Jul 24, 2022 4:15 pm
This is a problem Davie has had for ages, the plate brazed on the throttle shaft on the steering column has come loose, meaning that operating the throttle is awkward to say the least. We're about to fix it, but we don't know the correct angle between the plate and lever (later type shaft with Woodruff key, part no. 957E-9807B). Does anyone know the correct angle between the lever (or keyway) and the rear edge of the plate?
I thought we might be able to see on a Dexta we saw the other day, but when we went to have a look at it after doing something else it wasn't there, a friend told us that it had the same problem anyway, so it wouldn't have helped us for this.
