Fordson Dexta rear hydraulics problem - teardown and rebuild on YouTube…
pat777
Post by pat777 »
I recently came across a YouTube clip showing a complete teardown and rebuild of the Dexta hydraulics. May prove of some interest to other members as the topic seems to appear on the forum quite regularly. Unfortunately the clip is in a foreign language but certainly gives a good insight into all the main components of the system.
https://youtu.be/MpsyjGR86lc?si=OOHpMpL5E2o4jrnQ
Re: Fordson Dexta rear hydraulics problem - teardown and rebuild on YouTube…
Does look like a good view, only seen how they struggle with the modern seat so far.
Now seen the whole thing, I'm not keen on some of the things they do, but they did fix it. Didn't see them opening the unloading valve plug (a common problem).
