Dunggatherer wrote:You might want to invest in one of those "ball joint separators".
I always prefer them over a "pickle fork" or just hammering.
The first method usually ruins the rubber seal,the second kills the thread,and if you really have a bad day you may even break a steering arm.
The ball joint separator treats the parts more friendly,and you can probably get one for some 10 dollars.
Good luck.
Rob.
Hehe, as "luck" would have it, all of the above are already broken (rubber seal, threads, steering arm)
Actually the 2 front ball joints just fell out of their sockets when i started taking things apart!
I was going to start a new thread on it, but since i have already sorted things out (therefore no questions to ask!
), the 5sec story is that I bought the tractor knowing it had somewhat wonky steering and the wrong front axles, but it worked well enough anyways... until I broke the steering arm while piling manure!
After some research I discovered the axles (and pretty much teh entire front end!) were actually from a high-crop ford tractor (601 offset i think is what the guy at the shop said), and decided that i'd be better off spending a bit of extra money getting the proper front end from a wreckers instead of constantly dealing with the existing "hack job". So i'll be buying all new steering arms, drag links and ends, and front axles/spindles and wheel bearings. Hopefully with the correct pieces I can get the steering fixed up enough so that the steering arms aren't stressed when I bump into stuff! (i think my alignment was out due to the sloppiness in the bushings/bearings/etc and when i hit the manure the front wheels did the "splits"
edit: oh, and the one drag link was welded too... )
Ok, not quite 5sec version... maybe 25
Cheers,
Dan
