ford 8700
d.andersen
ford 8700
Hi i know its a newer tractor , but does anyone know the seria l numbers on the ford 8700 ??? or where to find them
Fordson forever
Re: ford 8700
On a metallised stick on plate that can be inside the cab on the right side in front of the brake pedals. It should also be stamped onto the top of the right hand implement mounting pads behind the starter.
d.andersen
Re: ford 8700
Post them and I will see if I can help.
