About 80+lbs each I believe. Does anyone know their dimensions?
Will they fit anything other than a TW?
http://www.ebay.com/itm/ORIGINAL-FORD-S ... 1e8adbb9ca
TW Rear Wheel Weights
SkidRoe
- Location: Tetenhall Wood, UK (was Thorndale, Ontario, Canada)
Re: TW Rear Wheel Weights
Our 9600 had rear wheel weights, but they did not look like this. They fit on the inside of the cast wheel disk, and likely weighted about 300 lbs each.
I have only seen this style of weight on TW's.
