Hydraulic selector valve knob label
bigmax7
Post by bigmax7 »
Can anyone please tell what the label for Hydraulic selector valve knob says ON A 4000. I have some of the wording left on the label. "PULL FOR ?????? MIDWAY EXT. & INT. ?????PLUS FOR INT. SERV.
5000blues
Post by 5000blues »
I think it should be PULL FOR EXTERNAL SERVICES
If you push it in the main quadrant lever works the lift arms, if the knob is out the lift armsstay in position and the quadrant lever works the external services.
Hope this helps.
The valve on the 4000 is a three way valve. In is lift arms only, midway is lift arms + external services and right out is external sevices only.
