Breaking a 1957 Fordson Major
Looking for parts? Got parts? Post it here!
Dietmar
Post by Dietmar »
I will break a 57 Major (no live PTO) during Christmas.
If some parts are needed pls ask
Dietmar
Hello Dietmar,
On this picture are the parts I still need.
Also the axle at the front to cranck the engine.
Dietmar
Post by Dietmar »
Dear Henk!
You have mail
Dietmar
llanfair
Post by llanfair »
Hi Dietmar,
Do you have the ignition/light switch.
Switch can be us as all i want is the ignition lock barrel, key not important. If you have please let me have a quote.
Regards, Llanfair.
Hello Dietmar,
Any change on a original working amp meter?
Dietmar
Post by Dietmar »
Dear Henk,
I will see if it is working and get back to you via e-mail
best regards
Dietmar
optimistjohn
Breaking a Major
Post by optimistjohn »
Hi Dietmar, I'm looking for the steel bowl on the bottom of the main air cleaner that holds the oil for the oil bath. (Apparently sometimes it also holds water.) Regards, John in SC
Tim en France
Parts
Post by Tim en France »
Hello
I don't suppose you have any parts left? I am looking for a descent radiator, nose cone & instrument panel.
Thak's
tim :?
bluecraig0776
Post by bluecraig0776 »
I'm looking for a crankshaft pulley :D
bluecraig0776
Also looking for handbrake lever :P
ed straub
trans plug
Post by ed straub »
Hello dietmar do you have the transmission drain plug by chance Ed
Need help with my back hoe blue ford majors 1960?? cant find serial number but engine number is 1509504 but 0s are funny shape kinda oblong I will take pictures and try to post Ed
bjelojac
head lamp
Post by bjelojac »
do you by any chance have a good headlamp bulb? can't find one local for a 1957 fordson major.
thanks
Bjelojac
