Fordson axle A frame
hi all ive just fitted a engine in my fordson but the a frame what goes from the axle to the sump wont fit properly. The hole for the pivot pin too go thru is smaller on the sump then on the a frame. So im either looking for a differnt A frame or a sump with the bigger pivot holes thanks for looking
Re: Fordson axle A frame
Are you sure the bush nr 3413 is still in the hole of the A frame?
The later super majors had a bigger hole in the A frame & sump, I know because I am just doing a similar swap and am having to put the matching super major A frame onto the tractor I put the engine into. I have got A frames with smaller pin hole but down in Hampshire ....
Hi thanks for your replys so if i get a standard major A frame it would fit on ? thanks
Yes because I have just done the opposite, getting the A frame off is the worst bit but you have to since the hole in the axle casting is also bigger on a super major. The bolts down through the axle will need some heat to get them out and even then expect to need new bolts! You could swap an axle and A frame but you will need to swap front tombstones too.
