Mine has seen some major trauma or modification in the past and has had some very dodgy welding done to it.
It is the large steel bracket that bolts to the front of the engine below the fan, the front axle is connected to it via the large bush and pin and the radiator sits on it.
Part number is 957E-3048.
Andy
Wanted - Dexta front axle support & bracket assembly
Dextrous
That sounds great Rob. I'll email you and sort out a courier to pick it up.
I've got a a Dexta instrument panel without the seperate ignition hole going FOC if any one is interested.
Also I had to buy a pack of 25 grommets just to get the big one that protects the hole that the tachometer cable goes through from the instrument panel. Fits really well. Again FOC if anyone wants one.
Andy
Andy
Free Grommet!
Andy,
Did you get my pm ref the free grommet?
All the best,
Ben
All the best,
Ben
