For Sale, Air Compressor driven off the front of engine where the power steering pump normally drives, attached to the compressor is the power steering pump (i believe this item to be faulty) there is a small resevoir that was bolted to the N/S mudguard along with a lever to apply the air brakes on the load being pulled there are also some of the pipes (some were damaged) and the pressure guage that was fitted into the cowl ( diesel tank cover).
All of this I'm told were genuine County items, I also have a huge 3/4 plate section that fits over where the top cover is on an agriculture spec machine and drops down either side of the PTO I believe it was probably for a crane to be mounted.
This all came off a 1968 County 1004.
Tel 01249 720570 or e-mail rscapriman@apeirce.fsnet.co.uk.
County Air Compressor, Resevoir etc
rscapriman
