As it says above I am looking for a cast lift arm with the extra casting for the pick up hitch linkage. I have 2 but one has very damaged splines.
Any help appreciated to complete my hitch set-up. Cash or swap for other fordson parts eg rear wheel weight etc
WANTED super major lift arm for pick up hitch
Roadless63
Matt 1944 N
Re: WANTED super major lift arm for pick up hitch
The top arms and the cross shaft on mine were very worn on the splines and it is very unlikely that if you do find any that the splines will be any good, what i did was bought a new pair of top arms and a new cross shaft and then made some bushes to go each side of them and welded them on using dissimilar rods and I added the gussets in and ground the welds back so that they look very similar to the originals I only have this photo of one half made one but if you want any more i will take some.
Matt
Matt
1945 Ransomes MG2, 1950 P6 E27N, 1963 NP Super Major
