Simms Fuel injector drive
jpettigrew
Does anyone have a good source for the drive pieces between the fuel injector and the motor? I am refering to the round fiberous disc and adjustable flange on the engine side. Have photos if needed.
Re: Simms Fuel injector drive
Hi- are you after a shaft and the drive couple part aswell ?! New of used ?!
jpettigrew
New or good used is fine. I am looking for the round fiber disk and the slotted adjuster piece that allows you time the injector pump.
I have a shaft and pump drive conection piece from an engine - straight out of a runner - that what your after ?!
I the adaptor available ? Mines worn. If so what size key has it got - I believe they changed the size at some point.
