Ransomes TS59e plough
Trevorthetractor
Post by Trevorthetractor »
:?: :?: Can anyone tell me how to replace the discs, they are fixed to the hub by what look like rivets. I need at least one new one as it is bent any ideas on who could supply them?
Re: Ransomes TS59e plough
Trevor,
Look at this site. Here you can find moost parts.
http://www.westlakeploughparts.co.uk/plough_parts.html
tom lad
Post by tom lad »
they are riveted on mate , but i have seen some poeples bolted on ? i dont know if this works in the long term .
when ive had to rivet things like that on i would bolt in on first to line up the holes .
i guess mark at westlake will know ?
hope this helps m8
tom
They are riveted, usually with hot rivets. You might need a mortgage with the supplier you suggest. :cry:
I believe "Old Twenty Tractor Parts" have some parts.
