Project: JAPA 1700 3.0 Firewood Processor
This is related to an independent part of a Major from the forest tractor project. Coming up there is a third element, namely the whole trilogy:), but it eventually.
This is the JAPA 1700 Firewood Processor, Vm. 1995. The machine produced 100 pieces, of which 10 units were sold in Finland.
The machine has been one of the owner of a machine was used professionally. The machine has been altered, protective structures removed, the wood removed from the ram, timber lifter removed and installed in power a Perkins diesel engine.
Project is to build the machine the necessary protective structures, wood presser, a new discharge conveyor, hydraulic supply chain and dispenser equipped with a conveyor to move the skeleton trees, etc. feed conveyor. So, here it goes .. http://japa1700.blogspot.com/
Re: Project: JAPA 1700 3.0 Firewood Processor
So it doesn't run behind a tractor? It has its own engine?aviator wrote:This is the JAPA 1700 Firewood Processor, Vm. 1995. The machine produced 100 pieces, of which 10 units were sold in Finland.
Looks like quite a monster
Originally it was a tractor to use, but the gear had broken down after which the machine owner had changed it to work with Perkins diesel engine. Transmission is carried out in a belt mechanism.Bensdexta wrote:So it doesn't run behind a tractor? It has its own engine?aviator wrote:This is the JAPA 1700 Firewood Processor, Vm. 1995. The machine produced 100 pieces, of which 10 units were sold in Finland.
It seems to me that it is a beauty and the beast at the same time
Project start. http://japa1700.blogspot.com/
Machine installation. http://japa1700.blogspot.com/
Engine 1. http://japa1700.blogspot.com/
Engine 2. http://japa1700.blogspot.com/
Transmission. http://japa1700.blogspot.com/
Firewood conveyor 1. http://japa1700.blogspot.com/
Firewood conveyor 2. http://japa1700.blogspot.com/
Firewood conveyor 3. http://japa1700.blogspot.com/
Firewood conveyor 4. http://japa1700.blogspot.com/
Conveyor is originally worked as a hydraulic motor. Machine the previous owner has modified the conveyor, and changed it to run an electric motor.Dandy Dave wrote:The converyor has an electric motor. Is it 220-240 Volt? Do you need to be near an electric power sorce to run it, Or is one of the motor units a generator? Dandy Dave!
Build a new long conveyor, and I use to produce the same electric motor.
Conveyor to an electric motor for the need of electricity, but it's not a problem because the machine is not portable, but I use it all the time and place.
Hydraulic log lifter 1.
Hydraulic log lifter 2.
