pierce ploughs
tom lad
pierce ploughs
Post by tom lad »
i've seen a pierce plough ?
2 f 12 " at the moment , semi / digger bodies ?
never seen one b4 , looks a tidy machine , any one any expience with them ??
the coulters look a bit ransomes to me , also the bodies look like a epic ??
link to the album , i think :beer:
http://s1098.photobucket.com/albums/g36 ... %20plough/
the ends of the cross shaft have two holes ? for the lynch pins , to take wider cat two links ??
over all i like it but cant get a answer yet if it for sale .
john.n
Re: pierce ploughs
Post by john.n »
could the second hole be for a stabaliser bar?
regards,
tom lad
Re: pierce ploughs
Post by tom lad »
i agree that seems likely , dont it.
bad idea to plough with a stabalizer tho in my limited exprience .
Re: pierce ploughs
You need a better picture Ben, it would help us comment.
The extra holes are possibly to aid penetration as in the later Ransomes ploughs.
tom lad
Re: pierce ploughs
Post by tom lad »
hi
does the link to the album work ? does on mine but maybe not to others ?? i cant tell.
Re: pierce ploughs
Post by Bensdexta »
tom lad wrote:does the link to the album work ? does on mine but maybe not to others ?? i cant tell.
Yes it works :wink:
tom lad
Re: pierce ploughs
Post by tom lad »
ta
Re: pierce ploughs
When I first saw the picture of the point and share, I thought, Ransomes Epic, but the shape of the breast is definitely not Epic which has a more square end. Looking again at the share, point and shin, it looks like Ransomes parts have been made to fit, by the gaps all around them and how the shin sits up higher than the breast at the front. Might be another contender for "ASP of The Year". :D
tom lad
Re: pierce ploughs
Post by tom lad »
i think i'll regret askin m8 but whats asp ? :scratchhead:
bitsa / basket case ???? :roll:
Re: pierce ploughs
Tom,
ASP = All Spare Parts
Bitsa = ( I believe) Bit's of this, bit's of that
Re: pierce ploughs
Bitsa = Bits a' this, Bits a' that. :D ,
As Henk says, ASP = All Spare Parts. It was coined by my friend J-P from Finland, many years ago, to describe his Fordson Major which he rescued and was using on his small holding over there. It became a standing joke between us and has moved into my slang terms. :D
tom lad
Re: pierce ploughs
Post by tom lad »
ok m8 i understand now :beer:
i agree lots of parts there
