Ransomes TS59e plough
Trevorthetractor
- Contact:
Re: Ransomes TS59e plough
Trevor,
Look at this site. Here you can find moost parts.
http://www.westlakeploughparts.co.uk/plough_parts.html
they are riveted on mate , but i have seen some poeples bolted on ? i dont know if this works in the long term .
when ive had to rivet things like that on i would bolt in on first to line up the holes .
i guess mark at westlake will know ?
hope this helps m8
tom
hope this helps m8
tom
They are riveted, usually with hot rivets. You might need a mortgage with the supplier you suggest.
I believe "Old Twenty Tractor Parts" have some parts.
