Coulter discs
Posted: Tue Feb 28, 2017 10:15 pm
On my Ford Ransomes EPJ plough I would like to assemble new coulter discs. For this, I bought 16-inch discs at a Dutch supplier. These are the same that provide Old20 and Westlake and correspond to the original Ransomes discs.
The discs are normally riveted to the axles. I’ve done this twice in the past by warm riveting. It gave no problems.
The disks I have now been heat treatment hardened and at the slightest heating they warp considerably. So warm riveting is not possible. After much searching I found a type of steel that is soft enough for cold riveting, but this way also deform and warp the discs.
I’m getting a bit frustrated about it.
Does anyone have experience with this and what can I do to solve it?
I know that bolting them on is not the right way, but I’m thinking of making a clamp disk with three M10 thread holes and put that in front of the disc and put the bolds in at the axle side. By using LocTide I can hold the bolds in place. Hoping that the discs are staying flat.
Would this work?
Would this work?
