Bespoke Dexta Muck Cart
alang
Post by alang »
Hello there,
I had an old dumper or a couple of years but the steering box bust. I took off the back axel, engine, gearbox and steering then just needed to tidy up the chassis and weld on a towing eye to reinforce the existing rear tow point.
The bonus was selling the single cylinder Lister/Petter diesel engine on Ebay for as much as the dumper originally cost me.
The lifting handle at the front is from the back cross member of a Land-Rover 90.
The Dexta pulls it well but you have to avoid tight corners.
Alan
:idea: :o 8) :lol: :clap: :beer: :yeah: :thumbs:
Huzey
Post by Huzey »
Thats well tidy. I am looking to do something similar using land rover stub axles, hubs and wheels for an IBC trailer to take 1000lts of water to irrigate my veg plot . I like the idea of a dumper though, very useful bit of kit I should think.
Regards Huzey
I started off with nothing, and have still got most of it left!
alang
Post by alang »
Huzy,
I'm trying to picture your bowser - is there anyway you can sketch it and show us?
Alan
Kiwi Kev
Post by Kiwi Kev »
Huzey
Here's a picture of my water trailer, that I use for carting water for our horses.
It's just a 1000 litre plastic tank in a cage, mounted on a frame on an axle/drawbar setup.
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Huzey
Post by Huzey »
Kiwi Kev wrote:Huzey
Kiwi Kev
That is brilliant, and exactly what I had in mind for mine. Like the wheels too, very smart.
I have got most of the steel now to start building. I am using a piece of box section off a big old Kverneland 6 furrow plough as the axle. I am going to get hold of some 10-12mm thick steel to make the back plates for the stub axles, and will use some old high voltage overhead line pole cross arms for the triangulation rails to a drawbar made from an old transformer channel section. (Handy working on the overhead power lines :D )
Once I get going with mine, I will stick a few piccies on here.
Thanks Kiwi Kev.
Huzey
Post by Huzey »
Finaly made the trailer
Will try and stick a few more piccies on when photobucket stops messing me about :evil:
Huzey
Huzey
Post by Huzey »
Right, sorted. A few more piccies.
And this is the pump on the pto for irrigation.
Will get some piccies of it all assembled and pumping.
Huzey
alang
Post by alang »
Huzy,
The bowser looks great.
Did you have to flush the container or was it guaranteed chemical free?
I see your not relying on gravity. Is the PTO pump for filling or emptying or both?
Alan
Huzey
Post by Huzey »
Hi Alan
Thanks for the compliment regarding the bowser. I must admit to being quite pleased with it.
The tank came from severn trent water and was cleaned out by them, so hopefully, should be ok.
The pump is generaly used for emptying through sprinklers, but could be used for filling if I can get close enough to the flood in the corner of the field without sinking!!!
Will get some piccies of it in action this weekend as the forecast is for a lovely dry weekend 8)
Huzey
woodseaves
Post by woodseaves »
I see this is an old topic but I am fascinated by the PTO pump:- where can I buy one?
