Nothing newsworthy at all
Allright, I've scrapped the thread, go away and do something else...
Please note!
The Dexta engine is NOT a PERKINS and is not the same as the M-F Version. There are major differnces.
We also have all the numbers listed on this site.
This information acn be confusing
The Swanndri Guy
Dexta's ONLY have Ford engines
Foxen, a question for you, do Saab 99's have a Saab engine or a Triumph engine? or Volvo V8's, do they have a Volvo engine or a Yamaha engine? (A bit of a quandary I think?)
As the block and the cylinder head of the Dexta were cast by Ford in Dagenham, so it is a Ford engine NOT a Perkins engine.
TSG.
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
The Swanndri Guy
Jerry, the simple answer as to who made the camshaft timing gear wheel on your old Dexta, it was Perkins. But probably a better answer to your question would be this. Considering the design of the Dexta engine is "derived" from the Perkins P3.144 and that FMC made the rough castings of the cylinder heads and blocks in Dagenham, all diesel Dexta engines were "assembled" by Perkins in Peterborough. So a number of the inturnal parts would have been sourced from Perkins and other manufacturers. Apparrently at Fords request, Perkins company name and trademark were supposed to be removed from all parts
. As for Perkins engines used in MF 35 3 cylinder diesel,MF 135 diesels,and Volvo BM 320 D would it not be fair to say that they are a development of the Dexta/Super Dexta engine?
TSG.
TSG.
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Re: Dexta's ONLY have Ford engines
Actually there were a number of SAAB 99's with Triumph engines and they were all quite miserable, about Volvo V8's I don't know since Volvo cars no longer is "Volvo", it's "Ford" but way back there was a V8 engine called B36 and that one was made by Volvo, it was a truck engine.The Swanndri Guy wrote:Foxen, a question for you, do Saab 99's have a Saab engine or a Triumph engine? or Volvo V8's, do they have a Volvo engine or a Yamaha engine? (A bit of a quandary I think?)As the block and the cylinder head of the Dexta were cast by Ford in Dagenham, so it is a Ford engine NOT a Perkins engine.
TSG.
Never mind...
The Swanndri Guy
Foxen ,the V8 in Volvo cars at the moment are a 4.4 litre 60 degree V8 designed by Yamaha. The point I was trying to get across is this, when we refer to an engines pedigree, is it the engines manufacturer, or the company who was responsible for the engines design? The Buick V8 is another classic example.
TSG.
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
The way it was said didn't really push that point, I felt it more like someone jumped me while yelling at me...The Swanndri Guy wrote:Foxen ,the V8 in Volvo cars at the moment are a 4.4 litre 60 degree V8 designed by Yamaha. The point I was trying to get across is this, when we refer to an engines pedigree, is it the engines manufacturer, or the company who was responsible for the engines design? The Buick V8 is another classic example.TSG.
I know very well that the engine in dad's Super Dexta is a F3.152(S3.152 anyone?), that the engine block and head are cast by Ford in Dagenham and it was then assembled in Peterborough by Perkins, the point is that it's a developement or derivate or what you would call it from the 3.144 that Perkins built, that's the relation this engine has to Perkins(from my point of view).
The Swanndri Guy
Ford engine, Dexta/Super Dexta.
If the F3.144 engine is cast by Ford, and is built to Ford specifications, then the P3.144 built by Perkins is their interpretation/clone of the Ford F3.144 engine.
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
