Weather makes a show and it certainly did on Sunday here. Not a cloud in the sky, bright , hot sunshine, one could almost believe summer was here. After the rain and cold of last weeks Shrewsbury Show you could have believed you had moved and gone to Australia!
Might have been the vine-yard tractor that was in the lines that made the difference.
Standing next to it was one I had not seen before. It had come from the Swiss border area and they were certainly proud of its name as this was cast into every available part.
But it had every sign of being a winner with Oscar
The tractor I would like most to take home, at least the one that would fit in my yard is this one.
An interesting tractor on view was the County Sea Horse. If you read the blurb, it was supposed to be the actual tractor that was driven across the channel in that famous publicity stunt but a plate with the build date contradicted that. Still what a beauty.
That is Mike and Colin admiring it.
There was also a Chinese tractor in the lines. Could not quite work out how it came to be in the vintage lines. Very much doubt it will ever reach the age of some of the exhibits, but it takes all sorts. Have not also worked out how a tractor, sold in the EU and subject to our laws, can have all the controls marked in Chinese, without an interpretation. HSE not doing its job perhaps.
The BIG boys toys were also there in force!
And, of course the tractor pulling,
And this one was doing rather well until something large and expensive went BANG in the rear axle,
But after all the noise and smoke of the pulling, in a quiet corner this old girl was ticking away and the gentle hum of the drum took us back many years,
This Dexta powered log splitter was working nearby and seemed to have plenty of power for the logs involved. This one however is not a good example,
Then, next to these working tractors and again hidden in the corner, a bit of a find,
The gentleman in charge said she is an original prototype Roadless that was used at the factory for a test bed. She had also appeared on the early leaflets advertising the Roadless system. She certainly was a Fordson ASP with a MK 1 engine with the throttle through the block but without the wide pulleys, a Power Major (?) gearbox housing or at least a 1957/58 one, a Super Major rear axle housing with dif. lock and disc brakes and a Major/Power Major lift.
It certainly was a mix of parts and just the sort of thing Roadless would do on a long term test bed tractor.
All together a very interesting day. Many thanks Mike for suggesting it. By the way, the gauge is faulty, I tried it on Nuffy this morning.
