TMAC
TMAC
Looks like we are going to have to put an APB out on Tmac, he's not been on here in a long time. I hope he didn't go barn storming and fly into a barn!!
See ya
Mark
Mark
Hi Mark
The trick is not that of flying into a barn, anyone can do that, the real trick is to fly out of a barn!!
I dont ever remember flying through barns, most have a back wall, not good for your plane! ;((
But a lot of hay sheds were used for practice! Those you can check out real good form the air as they have no sides or ends!
Got some pix of my summer projects but my dialup ISP is working so poorly that I cant upload.
Can hardly stay on the net to get email. They are working to fix but it isnt working yet! The one I have now is my only option as of now.
So will keep you and the gang posted!
TT
Hey Tom,
Yeah, you're right about the need for openings on both ends of the barn. I've seen some of the old pictures showing planes going through barns, knowing that the other door was closed. I guess people will do anything to get their 15 minutes of fame, even if there in a pine box six feet under.
Glad to see you posting. I was wondering if you were ill again, you usually post more that you have been.
That sucks having dial-up especially the super slow one. Are they going to upgrade in your part of the country? I know when I finally got DSL it was like putting two four barrel carburetors on a hot rod, super fast.
Good to know you're still kicking. Take care.
See ya
Mark
Mark
Meanderer
- Location: Elora Ontario, Canada (transplanted from Crookwell, NSW, Australia)
G'day Tom,
With your eyesight problems, I was wondering if you use Firefox Browser or not.
If you do, you can magnify the whole page by holding down the Ctrl key and then the + key as many times as needed to get the size to what you can see easily. Using the Ctrl and - keys will reduce the size.
I know they've introduced it in IE7 but I don't know if they had it before then. I haven't got it on my computer to check.
Hope that helps you and others.
Regards,
Rick
Regards,
Rick
