The above tractor belongs to a friend and he would like to know what sort of fluid to put in the reservoir for the trailer braking system, I suspect LHM. The reservoir is located above the slave cylinder at the back right hand side of the tractor and is only used to power the slave not the trailer brakes which are fed of the tractor hydraulics.
Any help/advice greatly appreciated.
