Ways to free a very siezed engine
Ben 26
- Contact:
I have an Allis ED40 with one stuck motor - any tricks on how to free it up
Ben Phillips
www.thetractorlad.co.uk
Re: Ways to free a very siezed engine
There's a thread here:Ben 26 wrote:I have an Allis ED40 with one stuck motor - any tricks on how to free it up
http://www.fordsontractorpages.nl/phpbb ... zed+engine
probably others too if you search
Some advocate diesel / ATF mix instead of coke. Or taking the head off and lighting a small fire in each of the cylinders.
Don't swing on the crank shaft too hard or you may bend the con rods or crack the pulley nut.
My engine was so seized with standing outdoors that each piston had to be beaten out with a wooden pole and hammer, even though I poured in diesel/ATF 2 months beforehand.
All the best,
