Anyway, the loading hopper motor suddenly stopped, no bangs or fuses went, just stopped. So i put 415volts to the motor and it buzzes, but doesnt move. You can just move the belt with two gurt bars on it, but the chain is SO tight, its almost as though something is jammed somewhere. Has anyone else had this problem?
Potato grader
Potato grader
Ok, a bit different, but i have just got in from a breakdown on a potato grader, couldnt do anymore cos it is dark
