12V Conversion
12V Conversion
Here's one for Brian.
Can you please advise me whether I need to change anything other than the control box and coil for a 6v - 12v conversion, can I get away with a 6v starter and dynamo??
Regards,
BarryT
Regards,
BarryT
Re: 12V Conversion
Hi Barry,
You need to change control box, coil and dynamo for certain, starter will possibly work for a while. Why not get another Dexta instead of this Fergy stuff.
Re: 12V Conversion
What do you have? A TO- 20? I've converted a bunch of 9N, 2N, 8N Fords for people who wanted them converted. And a few Fergies, I try to talk them out of it first though as there is nothing wrong with 6 Volt if everything is right. Often times slow cranking is caused by a dirty starter and mounting surfaces. Take it apart,clean everything well, and you will be supprised at how much better it will crank. Dandy Dave!
Re: 12V Conversion
It came at a knock down price Brian, could not refuse, it's a handy little thing. Dave I will try what you have suggested as the problem is the slow cranking. It's a 1948 TEA.
Regards,
Barry
Regards,
Barry
Tubal Cain
- Site Expert Team
Re: 12V Conversion
Barry,
I seem to recall that the 12 volt starter for these tractors is larger than the 6 volt and that the aperture in the back plate is too small for the 12 volt starter.
The little grey fella that I have used to start on the starting handle before it was submerged in the floods in Evesham some years ago. I haven't got around to running it since.
Gerald
Gerald
Re: 12V Conversion
There is a difference in the starters and also the gearbox casting for the different starters. I forget the reasons and models but I do remember changing an engine in one of mine to find the bell housing a different shape around the starter and being unable to fit either starter so having to resort to a starting handle. Glad those days have goneTubal Cain wrote:Barry,
Gerald
Fordson Super Dexta, Ford 4610, and Ford 3000
Re: 12V Conversion
Think its the other way around, the 6V starter is bigger than the 12V. The starter on mine is the same as on a Triumph Herald.
OOOOOOOps, thats done my street cred. no good
I have admitted to owning one!
Re: 12V Conversion
LOL...Brian wrote:Think its the other way around, the 6V starter is bigger than the 12V. The starter on mine is the same as on a Triumph Herald.
OOOOOOOps, thats done my street cred. no good![]()
The Swanndri Guy
Re: 12V Conversion
On the subject of "Triumph Hearld", Brian do you want another???
It 's not far from here, and for the right $$$ I think they would sell it
TSG.
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Re: 12V Conversion
Have you ever come across a Vittesse? Triumph Herald with a six cylinder fitted! Sporting version of the Herald. One thing that could be said for them all, you could get to the engine to service it.
The Swanndri Guy
Re: 12V Conversion
Yes ,there are still a few Vittesse out there.I guess they would handle a bit like a 6 cylinder Marina?
As a general rule,there is still a good selection of Triumphs TR, Stags, 2000/2500 and Hearlds out here.TSG.
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Re: 12V Conversion
Triumphs bring back memories! I had a girlfriend who ran a Triumph Spitfire!
Blast! I need to take more of the pink pills to stop the shaking
Re: 12V Conversion
Brian,
They were pink in your day then Brian!!
Regards,
BarryT
Regards,
BarryT
Re: 12V Conversion
Did not need pills of ANY colour then or now Barry!
