Right you lot! Lets have some order around here! The boss is back!!!!
We got home last night after a pretty hectic trip involving three to four hours delay on the flight which dropped us and 3 cases plus 3 backpacks in the middle of the London rush hour
That, and a case of falling down an escalator backwards being pulled by a heavy case, plus the rearranged Kings Cross station which is designed to train ( see the pun)? Olympic sprinters. They cannot tell you which platform a particular train leaves from until it enters the station, then you have 3 minutes to board before it leaves again!
You have to watch the departure board, then dash for the train amidst hundreds of other commuters.
Our train for Norfolk was twelve coaches long and you have to be in the first four as the train splits at Royston and Cambridge, so you can imagine the dash to get to the front of the train, fully laden with said cases and backpacks.
Whilst we might have gained a bit of weight whilst Down Under we sure lost a lot catching that train!
Got back into the house by 9 pm yesterday after travelling around 30 hours with little sleep, but it was all worth it. I have around 2000 pictures some of which will be going up on the board within the next few days and we have had some wonderful adventures with our Aussie mates which I will chronicle as well.
Look out for a new "memory" about the early years of the "X" series Fords as well.
