Page 1 of 4
60 farm fordson major diesel
Posted: Mon Jul 05, 2021 8:00 am
by christojo
Hi guys again from Australia. I restored a 54 petrol kero “Fordson major” with old post hole digger on front with help from this forum quite a few years back. Call me crazy but I have picked up a (60 Farm fordson major diesel) which is going to need a bit of work. It seems to be missing a bit of gear (fan, fan belt, wiring, key, alternator and brackets, front seal ) and the timing cover seems to be damaged and 1 tyre and tube is cactus. I’m not sure what else is missing as I am not familiar with the diesel. My question: can the damaged timing cover be welded? Or better to buy a decent second hand one? Am I able to put photos up of the bits I have to see if I am missing any more bits?
Thanks in advance
Dave
Re: 67 farm fordson major diesel
Posted: Mon Jul 05, 2021 11:23 am
by Billy26F5
For pics try this:
viewtopic.php?p=53955#p53955
I doubt it will be 67, probably 57 but the serial number will tell that. The timing cover is aluminium, so I wouldn't recommend welding it unless you know about it very well. As for missing bits we'll need the pics to confirm this.
Posted: Mon Jul 05, 2021 8:27 pm
by henk
You can solder it. But don't know if it is strong enough.
https://www.youtube.com/watch?v=0XEoCDLy-s0 (dutch video)
Could you please show us a picture from the emblem on the side of the hood to tell us wether it is a original Farm Major. And as Sandy say some casting codes will tell us a lot.
Re: 60 farm fordson major diesel
Posted: Tue Jul 06, 2021 1:54 am
by christojo
Posted: Tue Jul 06, 2021 2:30 am
by Billy26F5
It's a bit difficult to tell if everything is there or not, Major's use dynamo's, not alternator's, so don't loose the regulator. It does look like a Farm Major, which is unique to Australia; it's a Major Mk2 with Power Major instruments and styling (as far as I know, which in this case is not much).
Posted: Tue Jul 06, 2021 4:48 am
by christojo
It has the original diesel filter but think I will keep the cheap plastic one on it until I get it fired up. So It looks like I am missing a dynamo also, buggar. I will add a couple more photos to link of bits I’m not sure are their. Thanks Sandy and Henk
I will try and find engine number as well.
Thanks again Dave
Posted: Tue Jul 06, 2021 6:22 am
by christojo
Engine no: 573243 found on top of starter. Any ideas on what year.
Thanks Dave
Posted: Tue Jul 06, 2021 7:07 am
by christojo
I’m thinking there is a 1 in the front of the engine number. So thinking 60 model. If anyone can confirm, I will change the post to suit.
Thanks Dave
Posted: Tue Jul 06, 2021 8:05 am
by Billy26F5
That sounds odd for a 60 number to be behind the starter, look beneath injector no. 1 too. 1573243 is late September 1960. I recommend you refit the original filter and fit a new element in it before you even try to start it. You seem to be missing the core plug on the tachometer drive unit. Your block was cast on the 19 May 1960 (F19D), and you have a non original key or button starter in place of the original lever operated one. I recommend you change the engine oil and filter too before you start the engine.
Posted: Tue Jul 06, 2021 8:26 pm
by henk
The hood has the right emblem for a Farmer Major.
Posted: Wed Jul 07, 2021 5:31 am
by christojo
So it is a 1960. Thanks guys. I pick up the welded timing cover tomorrow and when front seal and gasket comes I will clean up and put on. I contacted the fellow I got the tractor off and he is going to try find the missing bits. Fingers crossed. I couldn’t find a number under no 1 injector. The cast number above dynamo is f13c.
Thanks again
Dave
Posted: Wed Jul 07, 2021 7:54 am
by Billy26F5
F13C is 13 May 1959. Try and find other casting codes to confirm the age of the parts, looks like the block sat in the spares department at Dagenham for quite a time, which is not common (but perfectly possible, Billy's front wheels are 7 years older than him).
Posted: Sat Jul 10, 2021 8:45 am
by christojo
I have taken more photos. There is more casting on head ( DDN and F2X ) there is also a casting number on the front under radiator ( F280 ). I have also photos of the spare bits for air filter which I can’t quite figure out ( I’m assuming there is more bits missing. If someone could help me out that would be great )
I have had the timing cover welded but still waiting for oil seal and gasket to arrive. There seems to be a spare oil filter in spare parts but it is different to the one on tractor.I am in the process of cleaning up the original diesel filter fo refitment also planning on just seeing if it turns over tomorrow to see if diesel pump is working. Fellow I bought the tractor off is still looking for bits for me but know luck yet. Also what size end for tachometer as there seems to be different sizes. And is there a cover on the end of tacho gear that covers the hole?
Thanks in advance
Dave
![Image](https://i.postimg.cc/FspLyHm4/B7-B4839-B-27-DC-49-F7-88-DE-42-E293423438.jpg)
Posted: Sat Jul 10, 2021 1:52 pm
by Billy26F5
The codes on RH side of the head are part numbers, the head casting code will be between the rocker cover and manifolds somewhere. The front casting will probably be F28C (28 May 1959) as O wasn't used. If you clean it it should show up better, look for more codes too. Good looking weld on the timing cover. This extra filter is non original as far as I can tell, it looks more like a second fuel filter though. Ensure the original fuel filter is totally clean and you fit a suitable new element to it (originally it took the AC FF23 element, but that is only available second hand as new old stock). Remember to bleed the fuel system thoroughly, try pressing the excess fuel button and then pulling the stop lever to the stop position and see if it moves nicely. The tachometer drive unit needs a core plug that matches the size of the hole. As for the cable you need one for a clockwise tachometer for a Power Major and a better pic of the tachometer would show if it's a Smiths or AC one (I think it's a Smiths one but I need to see it from closer to be sure). The small bowl with a tin on it is the breather for the timing cover, you'll need the upper part which has the filter mesh in it, it needs oil up to the mark and similar attention as the air filter; the clip and mesh are original but the bowl, plastic and deflector I've never seen, and I would say they're wrong. The radiator cap will need sorting but it should do for now.
Posted: Sat Jul 10, 2021 3:04 pm
by John b
If your front pulley has a groove worn in it from the old seal, fit the new seal in a slightly different position from the old one, leave it a couple of mm from being fully pushed into the housing so the new seal runs on a different part of the pulley and not in the worn groove. This is why alot of major engines leak at the front pulley
Posted: Sat Jul 10, 2021 10:55 pm
by Billy26F5
Having looked at more things it seems Farm Major's did have dual fuel filters, but I don't think they would be like that (not too sure about this).
Posted: Sun Jul 11, 2021 6:38 am
by christojo
Thanks for the information guys. I just checked the tacho gauge, it is a smiths. the cast on head is F2/7C
I’m guessing there is some sort of Walsh plug at back of tacho gear?
Also, is the ignition key a standed thing you can buy without machining or better to buy whole switch?
I still haven’t received the fan and dynamo from bloke I bought it off, is there a way I can hot wire the starter without dynamo or key so I can check if diesel pump works. ( so basically turn it over )
Thanks in advance
Dave
![Image](https://i.postimg.cc/jSYzXFnH/AA219-C3-F-2112-4-BD9-952-F-FAB95-C3-DA6-B2.jpg)
Posted: Sun Jul 11, 2021 9:02 am
by John b
Hi Dave, you should have 2 small wires going to the starter, one goes to the solenoid and the other comes from the ignition swith. Run a live wire direct from the battery to the starter in place of the one from the ignition switch and you should be good to go. Not sure about a replacement key for your original swith, Sandy may be able to help you with that one
Posted: Sun Jul 11, 2021 1:43 pm
by Billy26F5
Some nice pics there. The head casting code is F27C (27 May 1959) with the pattern screw between the 2 and the 7. It is indeed a core plug that is needed on the Tachometer drive unit, the tachometer cable you need is part no. E1ADDN-17365B.
I don't think you can get a separate key, ask the previous owner for it, if not you could dismantle the switch and take it to a key maker who might be able to make you a new one. As for turning over take a wire from the battery negative pole to the solenoid terminal that goes to the ignition switch COIL terminal and it should turn over, if it starts don't let it run for long as you don't have any coolant in it yet.
Here's the wiring diagram, it's the same for the starting circuit but not the charging one (you have the early five terminal regulator instead of the later four terminal sealed one).
https://www.fordsontractorpages.nl/ffcn ... _kroes.pdf
Posted: Sun Jul 11, 2021 3:27 pm
by John b
Sorry chaps, i should have read the post more thoroughly, i thought it was a diesel! Ignore my starter wiring and follow Sandy's
Posted: Sun Jul 11, 2021 3:34 pm
by John b
Just one cautionary tale about the first startup of an old major that hadn't run in a long time, and no, it wasn't me! A mate bought one and decided to put a battery on it as soon as he got it home. It turned over first time, then fired up, then sucked all the water that had got into the oil bath filter straight into the engine. Blew part of the head gasket out of the side and bent a con rod. He was not amused!
Posted: Sun Jul 11, 2021 10:18 pm
by Billy26F5
Dave's air filter is in bits, so no worries about that. The Farm Major wiring is the same as the Power Major, in Dave's case the type with the early regulator (the same as used in the early days), and the point about it being different is that Dave doesn't have the original lever operated starter.
Posted: Mon Jul 12, 2021 5:06 am
by christojo
Thanks again guys. I have put more photos up of spares. The little blue box in spares looks like it fits on the back of the regulator. I haven’t worked out where the regulator bolts up. Any ideas? I think I worked out the air filter in a video on link but not sure if the plastic cone will sit small end down or big end down. I’m thinking big end down as it seems to fit better without gaps Looks like I am missing the bottom oil bath of air filter but have the clamp. Bottom of air filter measures 160mm. The key in my 54 fordson works in the farm major ignition switch, so I’m guessing 1 key fits all.
Thanks for the link Sandy, that will come in handy.
Thanks again guys
Dave
![Image](https://i.postimg.cc/fyMGmKjD/E2-B8-D7-EC-873-F-4912-AE07-FA0-B6081-D4-C9.jpg)
Posted: Mon Jul 12, 2021 7:51 am
by Billy26F5
If the 54 key works that's very good as there are several. The box for the regulator is to keep it clean, the later sealed one is left in the open dirt. It mounts on that projection on the back of the air filter. I don't know that type of pre cleaner, looks pretty good but I don't know how it's meant to go. You are missing the bowl of the air filter, the mesh element goes between it and the body of the air filter.
Posted: Mon Jul 12, 2021 10:03 am
by John b
The filter bowl goes big end down, it's a dust trap pre-filter and meant to be emptied daily in dusty conditions. Not sure if its original to the farm major, but a very good idea in dry, dusty conditions. They normally have a wing nut on the top so you don't need a spanner to empty it
