Who can identify the machine?
Even the short shaft is a standard part. It is just an outer shaft that is used on the inside. I have been rebuilding an axle for my P6 and all the parts are all standard GMC, only the housing is modified.Roadless63 wrote:This one looks to be all there but you need to check out the front axle carefully, not all the bits are interchangeable with GMC truck bits, in particular the short half shaft.
What a lovely find you have there!county654 wrote:@ Pat
You are right, I think I got my present![]()
Today I tried to identify my new toys:
The Super Major ( with the french cab) should be a Juli 1961model, with corretc casting codes on all major parts. The engine has the numer S 455421, should be a replacement as far as I am informed.
When I bought the tractor, I didn´t know it has a raised ptoand very uncommen 38" rear wheels.
The 4x4 tractor should be a New Perfomance with castingcodes like 4C18 and 4C20 that tells a date in March 1964![]()
The engine is an older 1957 model and the not existing hydrauliks seems to come off an older model too.
I think this tractor had a winch mounted directly on the back and was working in the forest.
However the 4 wheel drive is in good shape.
With absolutly no Information about the history off the tractor I think I will transplant the 4 wd unit to one of my other Majors.
My favorit is the Power Major ....maybe in combination with the 6 Zylinder engine I bought in spring.
