Gearbox oil
billymajor
Gearbox oil
What grade of oil should i use in an 8 speed gearbox on a 954 super six County? I've tried EP90 but it boils under load.
Re: Gearbox oil
Welcome on this board.
I am not sure which oil you should use. Perhaps one of the other members of this board isable to help you.
Do you have a picture of your 954? Great tractors!
Best regards,
Pascal
Pascal
Re: Gearbox oil
Hi I just checked my 954 book it said use ford spec oil so checked in my ford 5000 book it says SAE 20w/30 or SAE 80 EP . I am in Canada and my book is for an export 5000 so not 100% sure if they used different oil for different climates. Maybe double check with a ford New Holland dealer in your country and see what they say for the 5000. I value my 954 highly and would not want you to add the wrong oil and screw yours up big time as they are pretty rare tractors.
Re: Gearbox oil
5000 tractors had a common gearbox and rear axle sump after about 1970 so if you are using 90W, the hydraulics could be boiling oil that thick.
No Ford tractor since 1959 has used 90W in the gearbox or rear axle in any climate as far as I am aware. Universal 20/30W or Ford 134 is the oil to use.
Re: Gearbox oil
Hi BrianBrian wrote:5000 tractors had a common gearbox and rear axle sump after about 1970 so if you are using 90W, the hydraulics could be boiling oil that thick.
it then goes on to list select o speed trans oil as ESN-M2C41-A or oil meeting ford spec.
after this it then goes on to say rear axle oil as ESN-M2C53A or ESEN-M2C86A or oil meeting ford spec or upgrade again I guess.
As it lists the trans and rear axle as separate oils it appears that the gear box and rear axle are seperate on 1965 5000 tractors that the 954 county is built on from what i can tell in the book unless it's just the SOS thats split oil
Just a little edit added here After reading this book more on the maintenance pages it has level plugs on gearbox and axle and drains on both so looks like they are seperate unless the seals go somewhere like the old majors do .
