Anybody got a diagram/picture/drawing of a selene / roadless frontaxle on a super major, diff. bearings etc.
also anybody know where to get new gaskets and sealings ??
roadless/selene axle diagram
d.andersen
Fordson forever
Re: roadless/selene axle diagram
Roadless manual
http://fordson.se/phpBB2/viewtopic.php?f=13&t=3159
I have bought some sealings from: http://www.terrangaxel.com/
d.andersen
Thanks .
got any experience in reversing the drive on the axles ??
Fordson forever
The only way to do it is to simply put the whole axle upside down. That is what they have done on Fordson Majors.
http://www.google.fi/imgres?imgurl=http ... 14&ndsp=20
http://www.google.fi/imgres?imgurl=http ... =0&ndsp=15
d.andersen
Ok but should it not be possible to simply turn the diff. Around ?
On roadless there is a extension axle for the pto ,
Do they also use that on selene , when the 4 wd box is not so
thick ?
thick ?
Fordson forever
d.andersen
the diff house is already sitting in the right side , but is
made for reverse driving (like on loaders)
Fordson forever
The gears do not fit the other way in the housing. If the axle is from a backloader you have to put it upside down to get it right for a normal Major.d.andersen wrote:the diff house is already sitting in the right side , but is
d.andersen
Grani wrote:The gears do not fit the other way in the housing. If the axle is from a backloader you have to put it upside down to get it right for a normal Major.d.andersen wrote:the diff house is already sitting in the right side , but is
Ok but then the drive shaft will turn forward would it not ?
And the bracket for mounting will then turn down will it not ?
On the picture of the truck/lorry you sent , the sits in the right
side that is not possible on tractor .
Fordson forever
With the two pictures you can se the diff at it´s original position on the truck it was designed for, and how it is the other way on the Major. The shaft is allways pointing backwards.d.andersen wrote:Grani wrote:The gears do not fit the other way in the housing. If the axle is from a backloader you have to put it upside down to get it right for a normal Major.d.andersen wrote:the diff house is already sitting in the right side , but is
d.andersen
Yes but as i can see , the shaft will then sit on the right
side
side
Fordson forever
