High idling
could the large spring that presses on the governer have got weaker with age. that would stop the rack being returned to the idling speed. have you got a spare you could swap the spring over from? try opening the valve a bit more and see if there is any difference. might just alter how quickly the engine revs up but not the max/min revs.
- Contact:
I have dismantled the vacuum housing from the pump.
There was a bit thin oil in the housing. The diaphragm was ok.
Like I have said before the damp valve was replaced by another one earlier. I think that must be the problem.
Has anyone a damp valve to take a look at or a picture?
This is what mine looks like. Total lenght 40 mm and round 8 mm.
How far will move the rod, that adjust the amount of fuel, in the pump move back and forward?
Strange thing is that the small pipe fit the large hole in at the vacuum housing and the larger pipe fits in the small hole.
Dismantled the cold start and shut off part to. That seems to be in good order.
- Contact:
Yesterday I have checked the stop/cold start unit. All was OK. Machined a new end button for the cold start button.
While I was reassembling it this evening, I thought I had a look behind the cover plate of the pump. Then I discovered a small nut. It was from the stop/cold start housing. Glad I opened the cover. I did not know there was a nut behind the screw that holds the housing.
Then I notice that the bushing that guides the control rod on the front was worn. That caused the ticking sound I was looking for the last four years. I always thought it was the coupling. Removed the bushing and I will machine a new one.
Could not find any thing wrong inside the pump that would cause the strange behavior of the throttle.
I thought the cold start/stop housing was fixed on with two screws? One accessible from outside the cover plate and the other one from the inside of the pump?
- Contact:
Put everything together this weekend. I expected the ticking sound would be less, but it made no difference. Only the stop/coldstart lever was stabilized. Before you could feel the fuel rod dancing.
I’m ordering a new diaphragm. There was some diesel between the pump and the diaphragm and it made a small dent in it. Worked well, but maybe this is the source of the problem.
I wrote to a pump revision company and hope they will or can answer my question.
Working on the repair story on my site. If you want to check go to repair page four.
http://people.zeelandnet.nl/hmdetroije/
