Pump will not fit on the major. Maybe you can use the original. Bracket for orbitrol must be modified to fit the major. Should be a quick job with a angle grinder and a weldersuper6954 wrote:Hi Whirlywhirly wrote:Very interestingfrode wrote:... My 654 had the same setup as the major and your 954. I converted it to real hydraulic steering. You are right, there is no rod coming from the steering box. The factory steering box is replaced with an orbitrol valve with a pressure feed from the power steering pump, return to the reservoir, and 2 lines going to the steering ram. The ram is just a normal double acting unit. Kit is part #6006 at Agriline. You can see how I modified it to use the orginal county bracket for the steering ram on the picture above.
Steering is now as light as on my Chevy full size![]()
Question 1: Is the orbitrol box a direct fit to the Major's steering box?
Question 2: How easy does the steering column attach to the orbitrol unit?
This would be a neat fix for my FPM with a Superior FEL. The steering is still too much for the wife even with an empty bucket
I have some sad news on what you asked about these parts![]()
Question 1 No
Question 2 this is a factory unit all in one piece in this kit so unless you got parts to custom build your own it is gonna be hard to do.
Sorry to have to add to your problems and I too wish I lived nearer and could be more help to you.
Just a question here what was the shipping on the kit and customs fees to bring it over if you don't mind me asking.
The steering shaft is supplied with the kit.
Frode
