Hydraulic wont work
Re: Hydraulic wont work
:clap:
We old members of this forum found out a long time ago, this is the place te be for all Fordson matters.
Keep up the good work.
dromonedog
Post by dromonedog »
You probably need to remove the piston in the top cover and clean and in stall new piston seals. Make sure the piston bore is good with no corrosion or pitting, also clean and reseal the valve body and make sure the valve is not sticking. I have done a couple of mine with good results
muhlig
Post by muhlig »
Can someone please tell me what the thread size and type is for the hole in the unloading valve plug. I have a 1962 super major and am having difficulty removing the unloading valve plug. I have tried a 3/8" UNF bolt but it binds after about 1 turn and will damage the thread if I force it.
Any help greatly appreciated.
Thanks,
Michael.
^Space^ wrote:I also own a Harry Ferguson To 20 a To 35 gas and a Massey Ferguson 50 E with loader.
Thats almoost cursing in the church on this site. :D :P :oops: :shock: :lol: :wink:
But since you are saving one of the girls, it will be forgiven. :clap:
