That is a funny thing, good luck.
Notice there is no wear on the clutch pedal.
But if i remember right the holes to the bolts holding the gear switch goes down to the rear axle. If you do not cover them it will rain in there.
									Fordson Major Pump install issues
Re: Fordson Major Pump install issues
1958 Major
1953-59 mix with backhoe Hymas type 3 (project)
1961Selene 4wd (project)
