1959 Power Major | Injector Pump Lever
Re: 1959 Power Major | Injector Pump Lever
If you do remove the pump make sure you mark the couplers as it is possible to put it back together 180° out!
JLworld
Post by JLworld »
Thank you John
You shouldn't need to remove the pump for timing, an easy way to avoid mis fitting the pump is to have the pump marks aligned and the flywheel at the correct timing with the clamp bolt on the pump coupling underneath. Loosen the claw bolts as necessary.
