How to change oil pan gaskets?
pat777
Re: How to change oil pan gaskets?
Post by pat777 »
If you check one of my previous forum posts, scroll down to the picture of the tractor seat and you will see a wooden clutch alignment tool that we made up on the wood lathe for aiding the realignment of my single clutch, might give an idea of the general shape required.
viewtopic.php?f=3&t=5885
IlkkaV
Post by IlkkaV »
Finally, today whole clutch package is ready for installation to the flywheel. Pilot bearing, clutch release bearing, pto clutch disc and trans clutch disc has been renewed. One question more, how to adjust the double clutch release levers without any special setting pad?
BR
Ilkka
Try leaving it to start with, but make sure all of them are the same, look at the manual and get the closest measurement from one and get the others to match. Don't do anything hard with your Dexta until it works properly.
IlkkaV
Post by IlkkaV »
Manual says that ensure the p.t.o and transmission levers adjusting screws project out of the levers approximately the same distance (3/8 inch, 9,53 mm). Is this meaning that 3/8 inch distance between pto and ttansmission levers adjusting screws distance or something else. I do not have so fluent english, thats why I`m asking to be sure.
BR
Ilkka
The 3/8" setting is to avoid the special setting tool getting stuck, measure all the clearances from the PTO disc hub, only adjust what is badly out.
If we could get dimensions for the setting blocks and the clearance of the levers from the PTO disc hub you could reset them, but I don't have these, so don't change anything unless there's one that's badly out.
