Not original starter
Re: Not original starter
Looks like they're not aligned. Make sure the pipes are perfectly aligned, otherwise they'll never seal. Don't be too scared about tightening, but I do recommend using a 4" long spanner as the original O1A-17015, for then you shouldn't risk anything, as long as everything else is correct. Don't use plumbing tape, as well as risking dirt it won't really work. You might want to check the straightness of the pipe ends, they should be completely straight for at least 1".
123Dexta
Post by 123Dexta »
Sandy, is there any chance of attaching the video here?
Many folk use youtube but I haven't yet so can't help you with that. Not sure what the video is for but I'm sure seeing it will answer that. Someone else might have a better idea.
123Dexta
Post by 123Dexta »
Here is the link to the video: https://youtube.com/shorts/afte1UtKjiY
The steering play is much too excessive. I’ve already installed a new steering kit (bearings, shaft, and seals), but it hasn’t improved. I also added a couple of 0.5 mm shims, one by one.
What could be causing this issue? I’d really appreciate any advice.
“Private Video”
No can see.
123Dexta
Post by 123Dexta »
That's a lot of play, and doesn't seem to be end play in the main nut. Did you replace the main nut as well? What were the rocker shaft bushes like? If both are ok then maybe the rocker shafts need work too. I'm afraid you'll have to take it apart again.
123Dexta
Post by 123Dexta »
I marked in green what was replaced. Everything was new from O20ld site.
Maybe the steering worm shaft, not marked in green might want a check too. Apart from the thread play can also develop in the recesses for the rocker shafts on it.
